2G Ecmlink swapping plugs question
bmw335ikt
228
16
Sep 23, 2015
Crown Point, Indiana
Hello, new to this. I have a 97 Gsx and bought a used dsm link v3 and the ecu has this one it md312464 e2t61672
4325 E
What year is this off and my Gsx has the cas off to the side of the head so do I have to switch the plug wires?
Anything else need to be done i saw something about switching injector pins? Thanks
What you have listed indicates a 95 Eprom ECU. All DSMs cave the CAS on the side of the head. 95-96 on the driver side, 97-99 on passenger side of the head. The following link may prove useful to you:
http://www.ecmtuning.com/wiki/swapplugwires
Yea thanks my cas is on the passenger side so I guess I have to swap the plugs. Thank you
Do you know if anything else has to be done? Thanks
I read the link and says that the wires have To be swapped are you talking about the cop system they are talking about at the end bc I'm not using a cop system
Thanks
With the stock coil pack, ignore the "COP" section of the Wiki. You just need to swap the plug wires as shown in the picture on the ECMLink wiki and enable the CAS Inversion option in 'Link.
