ECMlink ECMLink log, am I ok?
Nickhimself
May 12, 2014
Pontiac, Illinois
just did a stop to 4th pull and a 3rd gear pull it should be obvious in the logs, anyone wanna look them over and see if anything looks out of place?
here is the 3rd gear pull gunna try and figure out how to get the actual whole file uploaded
file attached to first post, didnt see that button there LOL, can i get some critiques or does it look good? just started messing with it
the set up
2.0 6 bolt bottom end
Fully ported head
3G revised lifters
1mm oversized Brian Crower titanium valves
Brian Crower titanium springs and retainers (2100) kit
Brian Crower 280 cams
ARP L19 headstuds
Magnus sheet metal intake manifold
Slowboy racing 4 inch race core FMIC
FIC 850 injectors
Aeromotive fuel rail with 255 pump -6 an feed from tank
Aeromotive afpr
16g turbo
kinda learning this stuff on the fly, ill look into logging it, its hooked into the o2 in the front, so i guess i thought that was it LOL
here is the same log with afest on it.... not sure if that will help at all or not tho
i havnt personally touched this since i got the car, to be honest its kinda above me right now... he said the sd table needed to be like that bc the turbo runs out of breathe at 5500 rpms..... im begining to think that i have alot of issues on my hands
ok well ive been toying with this thing all morning/afternoon watching videos and reading posts on posts on posts and i just cant seem to catch a grasp on it, looks like im just going to have to find someone who knows what the hell they are doing and buy them a case of beer or something -_-
ya i figured out how to get everything logged, its just adjusting the SD table, i really have no clue what im doing or what to look for in it, also everything i read refered to the MAFraw in volts and mine is reading in Hz and i cant for the life of me figure out how to switch it so that i can set up my limits
ok so heres a log of the car idling after 4-5 mins running in openloop a/f looks a lil on the high side but a pro input would be great also not sure what the hell i should do about this
If it was me, I'd set the SD table back to a stock one and start over.
You will never see knock with the settings you have on the ALS/Knock tab. You should lower the RPM to around 2500 and the TPS to 30% or so.
Add these values to your Captured Values list:
SDAirflowPerRev
ISCPosition
Your car is stuck in Open Loop, which means it's constantly taking the target AFR from your DA fuel table and not the front o2. Figure out which reason from the following link is causing it to switch to open loop and correct it.
http://www.dsmlink.com/wiki/fueltrimupdatepoints
when its first fired up it runs in closed after a few mins it goes to open, and anyway to reset the sd table without reseting every single setting?
