ECMlink ECMLink Drivers Not Working on MacBook Air
bo0st2
237
51
Dec 25, 2023
Arizona
I am running into a problem and was wondering if anyone could assist please.
I'm running a Macbook Air with these specs:
And with those specs I am unable to install any these drivers: (from https://www.ecmtuning.com/downloads.php)
It says the drivers are for 10.4+ and above, well I got that version 12.7.1 and it's not working at all..
There's a couple different files in that download, I click on each one & what happens when I do is I run into these messages:
This one looks like it's about to work:
then it gives me an error
if I install this on a Windows laptop it works fine
Even works fine on a Macbook Pro running macOS Sonoma 14.2
Now as a workaround I'm installing Parallels on this MacBook Air so I can run Windows on it & hopefully ECMLink will work that way
Update: Works well on Parallels
but it should work on the MacBook Air regardless so any tips/tricks would be appreciated.
Already posted this on the ECMLink forums just wondering if anyone here had this issue before
I saw your original post and wanted to help. I use a bootcamped windows 10 or the intel osx partition. This is on my 2017 intel based MacBook Pro.
I have a M1 MacBook Pro as well. If there is something you would like me to test for you, I can try Martin Luther king weekend.
With the air running an intel i5 it should just work?
I think the download should just work considering my stats but it’s not allowing me to install any sorta drivers on the MacBook Air - not unless I load windows 11 into it, then everything works fine.
I can confirm ECMLink works fine on the MacBook Pro I also have.
Its just real finicky on a MacBook Air but it shouldn’t be according to their site it should just work since I’m running a version above 10.4
I'm about to sell my ECM Link and just upgrade to Haltech Nexus S2, just because I can't connect my macbook to it anymore, they aren't following the updates and I just don't want to be buying slow, old dinosaur tech laptops in order to tune and diagnose the car...
