Eclipse Spyder Light Bar Template for cutting rear quarter panels
libertad83
Nov 2, 2013
LIbertad, California
Hello,
I need to install a light bar on my 97 Spyder. I found the installation instructions at Mitsubishi Eclipse Light Bar Install
The above links refers to a template for cutting the rear quarter panels. Does anyone know where I can get this template? I tried searching for it on the forums and Google without any luck.
Any help is appreciated
Thanks
It says right in those instruction." a. Use template provided to mark hole locations in the top of rear quarter trim panels. Drill 1/8" pilot holes then follow with a 1 3/4" hole saw, drill though trim panel and the metal support immediately under trim panel."
In other words it comes with it.
I purchased the light bar from Craigslist. Your suggestion doesnt apply.
Damn! I have been wanting and looking for a light bar for a long time and there you go just scooping one up. Deft Racing and Classic Design Concepts were the only ones I've come across that once offered the bars, but they are no longer in production.
I'd say you could attempt to contact CDC. They may still be able to retrieve the template for you. If I come across anything, I'll follow up with this thread.
