2G Eclipse GST overheating issue
Velmin hu
69
May 25, 2019
Las vegas, Nevada
My car just recently started showing a hot temp. It does not go into the "danger zone" on the temp guage and it fluctuates while I am driving and sitting in traffic. It hovers between normal and about halfway to the "danger zone". Sometimes it will go up or down when I am driving. Sometimes it will go up or down when I am sitting in traffic. There doesn't seem to do one thing or the other consistently. I checked the coolant and it is full, however when I opened the hood after shutting the car off, I heard a "bubbling" sound. Like boiling water. Any ideas?
engine has 80k miles stock intercooler evo 16g big, down pipe, 550cc injectors
can you please help stock thermostat and radiator cap
Have you check your radiator conditions? Also are the fans turning on,.
When the car is warmed up check the radiator to see if it’s not clogged, remove both bolts on the of the radiator and move the top of the radiator towards the front, you will beat able to stick your hand behind the radiator to touch it, if it’s clogged you will feel cold spots on the radiator panel, if Tere is cold spots then radiator is no bueno.
Fans turn on when I press AC button and when I turn heater on no ac button fans don’t turn on
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
