EBrake Help
brandonsask8er
Feb 22, 2005
Marietta, Georgia
SO i did a search and couldnt find anything that would help. I had my rear rotors spun yesterday. When i drove my car today it felt like the brakes were still engaged even though i wasnt pressing on them. Also it smelled like they were burning up. I used all the correct tools in the reinstall of the brakes made sure not to use C clamps just used some needle nose plyers and turned it untill there was no more pressure.
1992 n/t eagle talon
If you installed new pads you ned to adjust your parking brake that should fix it. A way to check it is if your e-brake dosn't click but a couple of times, that means it's to tight.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
