ebay turbo or???
Sneezin
56
Oct 2, 2013
saukville, Wisconsin
This turbo was on my car when i got it. And it doees nkt have the 052/047 ect to tell which 16g it is. Or is it even a true 16g?
Thanks guys for the helpful replies! I am upgrading to a hx40 soon so this is on at 22psi until the i find a hx40
Yeah. I actually have changed my mind on a turbo. Going with fp black. Aiming for at a bare minimum 550+awhp by spring
hx40 beast! Im looking to run a dbb turbo it runs so much smoother and more effiecient.
Smoother? Sure, in some ways. More efficient? No.
A T3 frame HX40 would breathe MUCH easier than a FP Black at that level. Anything in a 8cm (or equivalent) housing is going to require alternative fuels to make 550whp happen.
Thank you Justin is it? I was hoping you would venture here and give your imput. Thank you!
The part number on the cover as well as the wheel's shape and compressor inlet design.
If it has the little round "circle" machined into the cover where the part number is, it's a Small 16G. This is because the Small 16G was designed and produced after the Big 16G, so the Big 16G covers which were cast with "01__0" into them (for either a 42, 45, 46, or 47 to be placed depending which unit it is) were simply machined down so the Small 16G part number could be engraved.
Every Small 16G is that way:
