Ebay Manual Boost Controller
I had one for the first few months because everyone said I needed one, I never turned the boost up or anything but it worked fine none the less. Easy install and it cam with routing instructions.
Give you a hint click the make offer option and shoot him $15.00 and its yours right off the bat saves you 5 bucks and he is a great seller I have order like 3 of them and they work great. Plus lifetime warr. cant beat that.:rocks:
I already bought it and i did do that thanks though:thumb:
I am a newb to installing. All i have done to my GST is hard UICP and intake other than that it is stock. Is the installation easy for this MBC?
Thanks for any input
It most likely will provide an indadequate amount of vac line, but you could pretty easily go to auto zone and buy a silicone vac line kit in red for it, and even change more things. Personally i dont reccomend any ebay boost controller because i was shipped one that didnt work, and joe p's are cheap and the best controller around other than some ebc's.
Yeah i had that same mbc. It comes ready so you can run boost safely. And yeah it did't come any hoses just wrapped up in the directions. Its pretty good. Good luck.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
