Easy to take out interior? and how to on a 90?
KillerX
60
May 27, 2006
Strathroy,
I thought there was a write up but I couldent find it. I want to take out my interior from a 90 talon and put in a interior from a 91 laser but how hard wouyld it be? also wheres all the screws i gotta look for... im more worried about the entire dash more then anything...
Brad :)
By interior, do you mean like the paneling, or all the seats and everything? I've taken out most interior parts in a 93 talon, as well as my 90' gst. The dash is the only thing I haven't taken totally apart, but most everything will come apart if you look hard enough for the screws and coax carefully. The biggest thing I'd warn about is that alot of the paneling is held on not just by screws but also pop clips (if that's what they are called?). Basically you need to slide most of the panels in a certain direction while prying them off, or you will just break the clips. If they do break, you still have screws for most of them. Hope that helps you! If there's anything specific you're wondering about, I've probably taken it off. ;)
