easiest way to get the bolts off the 2g o2 housing
This guide shows how to remove the o2 housing: http://www.dsmtuners.com/forums/art...4675-innovate-lc-1-wideband-installation.html
The trick is, you can actually fit a breaker bar + socket on the rear bottom bolt (as well as the top bolts). Once you get a breaker bar on there, it's a piece of cake :thumb:
Ran out of light got everything off except the water line I have 0 room to get it off itz pissing me off, oil return is blocking me from turning it any farther about to cut it off idk the flare wrench isnt working like i said i got no room to turn shit after the first turn
Taking it off isn't bad it's the getting it back on.
+10000
Unless you want to dismount the whole shebang and throw it in a vice your other option is to more or less to just put up with the pain.
I'm not sure what I hate more; R&R the 02 housing, dropping the transmission with nothing but hands, or R&R the A/C pulley.
Actually, hands down, it's the A/C pulley but none of these things are pleasant.
+10000
Its like a false sens of reality your all like damn im flying through shit is easy then bam you see that last little screw hiding in the dark your whole world gets turned upside down leaves you like wtf, im ready to go finish this thing right now one thing i can say is that this thing is not as hard as a vr4 to work on my VR4 is a mjor pain in tha
+10000
I need a ac belt and pulley and took 20 minutes at it and was like screw it I have windows. Who needs ac.
