e85 & meth simultaneously
The reason it is not really needed is because the octane of e85 is high enough to run the amount of timing you would need meth for with pump gas. The only benefit I see from running meth is actually spraying more water and to cool the intake temps alittle.
Its like running race gas and meth. Its not worth it.
John told you exactly what you need to hear. There isn't a point to running meth unless you are using it to cool the air charge more which lowers knock but E85 doesn't need it.
Sure it wouldn't hurt to use it but you prob. won't see any benefit to it other than clean pistons and a colder air charge.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
