E3B16G Water feed and return lines
96talontso
300
Jul 12, 2011
Edmonds, Washington
Need to get coolant lines for the turbo, and the original kit that i bought had the wrong size. What lines should i get?
Well if you need the lines off the turbo you need these.
Feed line: EXTREME PSI : Your #1 Source for In Stock Performance Parts
Return line: EXTREME PSI : Your #1 Source for In Stock Performance Parts
Banjo bolts... You need 2 of the 14mm ones:EXTREME PSI : Your #1 Source for In Stock Performance Parts
2 crush washers: EXTREME PSI : Your #1 Source for In Stock Performance Parts
Then you need some rubber coolant hose that you can pick up from any parts store from these lines to the lines on the water pipe/thermostat housing.
You should be able to use your stock coolant lines and banjo bolts. I even used the crush washer from the t25 and it never leak. And to make it fit your going to have to bend the coolant line a little bit.
No kit that I know of, comes with any coolant lines.
Use the original coolant lines and banjo bolts, grab some new crushed washers.
I had to bend my lines on an FP Green almost nothing, I'd imagine I'd be the same for the 16g.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
