dvd flip up pocket logger
you can do what im planning on doing and using a pc with either dsmlink or ecu+ and run the video out from the video card to the monitor as long as its composite out
Personally, I just have a datalogger cable (ie: you don't *need* ECU+ or DSMLink to just log) with Tunerstein, and pipe it to a 5.5" LCD via composite from my laptop. You will not be able to log 'natively' with the DVD flip-up, unless it's an integrated carputer that you can load the software onto and run.
  • Wanted 6 bolt NT water pipe
    • chrisman287
