ECMlink Duel Fuel Pump setup
a91eagletalon
Supporting Member
278
13
Aug 24, 2005
Norfolk, Nebraska
I have a question is there a way to get ecmlink to turn on a second fuel pump
I will be running duel walbro 255 pumps and only need one pump running under normal driving but will need two pumps running under boost is there a way to trigger the second pump to turn on after I hit a certain boost presser
Thanks
MJP
Yep. You use LINK to activate one of the accessory solenoids on the firewall for use to ground the second pump and activate it. We are doing it right now but are just at the wiring of the second pump. I will add details as this project gets completed. It is on my sons car and is being tuned profesionally so as it goes I can tell you more.
