Fuel Setup Question
5150
167
Nov 21, 2004
Vacaville, California
Ok my mods are in my profile, and what im doing is im about to order my afpr and pte
780cc Injectors. Now i plan on running DSMLink but dont have the money for it right now. So i guess my obvious question will be will i be ok for now on 12-15psi.
I don't see a tuning device at all in your mod list, so don't even thing about installing the injectors yet. If you are getting DSMLink I would suggest at least a set of 850s (or 880s if PTE) minimum. They'll carry 90% of the people on this board as far as they will ever go. Although if you have to go with a SAFC then 780s are pushing the envelope of what it can do...........some say it will do it, while most say it won't. I haven't used a SAFC so I can't say.
However, as soon as you get the AFPR, install it.
Well i never said that i had a tuning device i said i was going to get one. And as far as the injectors go i was under the impression that 750s or (780's) were all i needed, so are u sure that 850's arn't too much?
But getting back on point, you did answer the question at hand wich was wether or not i should put the injectors in before i got DSMLink, and for that i thank you.
850's are too large for an 18G. I'm rockin a 60-1 and havent even came close to maxing out my 780's.(i've only run about 22-24 max boost tho.)
**dont install the injectors before you install dsmlink.**
DSMLink has controlled 1600cc injectors, so a set of 850s is a no-brainer. With the price of injectors the difference between a set of 550s to 850s is minimal. I suggested a set of 850s, not because I think that's what you need, rather that it will more than likely carry you until the end of your DSM days. IMO you should make your fuel system as large as you can control, and as stated DSMLink can control large injectors and still idle like stock. IMO you can never have to much fuel available, you may not use it, but it's there if need be.
It's not that I "said" you claimed to have a tuning device (sorry if I did a rare thing and looked in your mod list before I replied), rather I was stating that WITHOUT a tuning device.............don't install the injectors yet.
(man, this time of year everyone acts like you're "pissing in their corn flakes")
sorry if it seemed like i had an attitude thats not how i was implying it. But i do appreciate the help.
