Fuel pump
If you asking can I reuse the walbro in my 1G FWD, the answer is yes. It's actually the same pump in the two walbro kits with different install parts. From what I remember, it should fit easier in the FWD fuel pump assembly than it did in the AWD fuel pump assembly.
Steve
94Jettameowpsst said:
Good stuff, thanks, i just wanted to clear things up since i heard the pick up is different from an awd pump to a fwd pump.
The fuel sock is different but so is the pump, electrical wiring, and attachment. But like I said the walbro pumps are closer swap on the FWD assembly than they are on a AWD.
Check the two different VFAQs to see what your in for.
http://www.vfaq.com/FAQlocator-fuel.html
Steve
