Spoolin98
- 1,646
- 23
- Feb 1, 2004
Easton,
Pennsylvania
Im upgrading to dual piston calipers and I have a question. I just removed the single piston caliper and I hooked up the dual piston caliper. With just the brake line hooked up and the caliper sitting on top of the rotor when I press the brakes only one piston comes out and the other stays in. It did this for both the dual piston calipers. I did not bleed the brakes, I just hooked them up quick because Im getting ss lines and new fluid so Im not going to waste my time bleeding them.
Is this normal? Or are both of the used calipers I bought broken?
