dual piston calipers in rear??
SFRacingGST
235
May 4, 2004
Warren, Rhode Island
i just recently upgraded to the Baer Front claw breaking system.. was wondering if any one has tried to put the stock 2 piston caliper on the rear to replace the one piston stock caliper???
Would it bolt up with the back bracket, or would i need to get the hubs like the front for the rear?
Do you know what the piston area is for the 2-piston fronts? Without the world's weirdest prop valve, you'd be dead at the first corner.
Do more reading on brake bias before continuing this thread.
- Jtoby
Front to rear caliper piston sizing is based on weight distribution & CG height...etc. You do NOT want to increase your rear brake bias without brake-system smarts, it is not safe.
Buy a book called The Brake Handbook... I think it is by Fred Puhn
thanks for the reply, i wasn't sure about this, thats why i posted this topic. Just seemed like i have some bad ass front breaks now and the rear are so cheesy.
Gross over amount of rear bias. Wrong rotor. Not even close on brackets.
Only production caliper that 'might' be worth considering is the rear part off a 3Si. Two pot opposed for a vented rotor. Swap the rear now to the vented one and hope the caliper mount centers are even close.
When done what will you have? A fixed caliper with two pot opposed design. Same basic piston area so no additional clamping. Which isn't such a bad thing.
