Dsmlink connection problems?
EclipseGst1992
60
Apr 27, 2009
Stevensville, Maryland
I have an eee pc and when I plug in my car to it and try to connect with dsmlink it says it can't find a connection or something with the comport. I tried installing the driver using the files on dsmlinks cd. I believe it said cdmi something. It seemed to install but still no connection. Is my CPU bad? What's up with it?
You are using a USB-COM adapter right? You need the driver for the adapter if this is what you are doing.
oh.... well the cord that came with dsmlink v3 is a usb end... what exactly is a com then.... im just trying to go by the directions on the disk
Does v3 work with windows 7?
Yes, I use Windows 7 on a 5 year old HP laptop to tune.
I had a connection problem at first, but after I redownloaded the driver and the latest v3 application, it works just fine.
When I go to device manager on my computer there is no port treemto expand. I tried installing a port hardware but after I did there is a little yellow exclamation point on the port that I installed but the tree was there then.... I don't know why but it seems my CPU doesn't have the ports installed
Well actually now that I think about it i had my external hard drive connected to it by USB and it worked fine
had a similar problem check your pc make sure its has windows and also check to see if there are any lose grounds around
