dsmchips.com stage 3 chip, about stutterbox???
91-gsx
932
11
Mar 31, 2005
San Jose, California
heyi had a quick question is anybody else having a problem with their stutterbox? the people at dsmchips have told me it is my clutch switch that is not working, but if it did not work, would i be able to start my car sense you have to push the clutch in to do that? basically i set the stutterbox at 4,500 and when i rev that high it does not just stutter, it goes right past it as if there was nothing there, all the way to redline. and i have spliced my ecu and the clutch switch wiring before anybody asks.
plz help i wanna get this to work
When you turn the key to the "on" position, motor OFF does the stock boost gauge jump when you tap the throttle like the directions say? If not remove the negative battery cable and redo the installation of the diode and woires, including the new clutch switch. I just changed my DSMchip and the stutterbox feature did not work. I went through the connections and checked them all. Taped some where the wiring was exposed. Now it works on the stock boost gauge.
Grey wire goes to the ECU. I can check the others if you need. I would redo the set-up. It's a pain messing with thre ecu the way it's placed but there must be a loose connection. Also SOLDER the connections, not just twist the wires together. PM me if you need further assistance. mark
