dsm link need ATEN driver to hook up to laptop.
cirilo
Oct 30, 2005
West Chicago, Illinois
ATEN KVM Switch - Simply Better Connections
is this the right place. and wich one would it be?
Now plug in the usb to serial adaptor in the car into the PC. Windows will install drivers for the ATEN device. If it does not, go to ATENs website and install the drivers.
I went to the web site but dont know what exactly to look for.
can someone just tell me the what driver i need to download. or a link to where i can download this driver from.
Most people use a Keyspan adapter for a USB-Serial conversion. The DSMLink forums have a list of adapters that work well for DSMLink.
thanks ill have to give it a try tomorow. ill let you know if it works.
2G 1995 MITSUBISHI ECLIPES GST Red M/T MODIFIED STREET 2.3 STROKER engine 1g in a 2g conversion. Engine built by FFWD connections www.ffwdconnections.com· 90' style block cryogenically treated – balanced shaft removed· Bored and stroked, o-ringed block, Ross pistons ceramic coated, crower rods, (rotating assembly has been cryogenically treated) · APR hardware (head bolts), all metal head gasket · Heavily ported and polished 1G head from FFWD. D-shaped intake/exhaust ports, 2mm oversized valves, Stock cams, cam sprockets and lifters. Candy apple red valve cover. NGK plugs (2temp range cooler), magnecor wires · NGK plugs (2temp range cooler), 8mm magnecor wires Clutch master billet aluminum flywheel w/ steel ring gear / steel replaceable friction surface. <500 milesPorted stock header, modified for a Hahn race craft super 16G turbocharger.Road race engineering 3" DP, 3" cat, 3" apexi N1 exhaust* (can is rusting, will need to replace) K&N / chrome injen intake to turbo, RRE intercooler piping, 60mm modified 1g throttle body, 1G BOVAfter market chrome FPR, modified 8AN fuel rail, earl's fuel filter, 8AN fuel line to Nippondenso fuel pump,V2 DSM link fuel management system with 2G ECU. Apexi super AFC II fuel controllerAutometers, O2 meter, Oil Pressure, boost, pyrometer (exhaust temp), Clear tail lights with LED lightsPolyurethane motor mounts / trans mounts (also have bushing kit for suspension +lowering springs never installed)ATC 2600 clutch <500 miles TRE- rebuilt street-strip Trans www.teamrip.com/DSM_FWD_STAGE 2_REBUILD_SERVICE.html· Quaife ATB helical limited slip front differential· 16% taller 5th gear (great on gas mileage) approx 2200rpm @ 60 mph· Double synchro 1and 2 gear set· New high friction 1-5th synchros· New 1st-4th hubs & sleeves· New 1st-4th shift forks· New Input shaft +bearings· New Intermediate shaft +bearings· New needle bearings under 1st -5th gears· New oil seals· New synchro keys· New synchro key springs· Neodymium trash magnet, oil filter and magnetic drain plug.· New snap rings, heavy duty double roll pins, end nuts, bearing shims and all the other non-reusable's· All gears & shafts stress relieved, de-burred and modified for durability and improved shift quality.
