dsm guru's help me out!
mostlygobitshow
Oct 27, 2004
Ft. Collins, Colorado
So, I thought I had fuel cut as mentioned in my last post a couple days ago. I changed the fuel filter, then got all new plugs and wires. Did the maf mod and still had the problem. So I decided the only way to get away from fuel cut is to trick the mas into putting more air in without it knowing hence I went, aww, what the f#$@? I'll just completely remove the plug I had on my 1" recirc off my intake that goes to BOV. It worked! But as you would guess I'm probably runniung really lean(need to hook up my A/F gauge). Also, it created an artificial vacuum leak which makes the car idle ruff as in it starts to drop, mas brings it up, and so on and so on. Is there another way of bring more air into the engine w/out the mass knowing it but not creating such a bad vacuum leak? Let me know guys! Thanks for all the help with my last post. No fuel Cut! YES! Idle horrible.
2g MAS is your best option still its cheap and it works well. Can't say the venting was the best idea in the world but if you can put up with it its your car good job on fixing it.
