DSM adjustable shifter bushings
Status
Not open for further replies.
DSMboostinawd
Mar 15, 2008
Mundelein, Illinois
Hey guys, I got some shifter bushings for you.
<a href="http://s280.photobucket.com/albums/kk170/kabamm522/?action=view&current=IMG_0790.jpg" target="_blank"><img src="http://i280.photobucket.com/albums/kk170/kabamm522/IMG_0790.jpg" border="0" alt="shifter bushing"></a>
These are not the shifter base bushings nor the under hood cable bushings.
These bushings are the ones that are used to bolt the shifter cable bracket to the trans. I looked long and hard for these bushings and no one sells them.
The image above is for a 1g, these bushings will make your shifter firm as hell.
4 bushings will be included in a 1g kit.
<a href="http://s280.photobucket.com/albums/kk170/kabamm522/?action=view&current=IMG_0793.jpg" target="_blank"><img src="http://i280.photobucket.com/albums/kk170/kabamm522/IMG_0793.jpg" border="0" alt="bushings"></a>
But for a 2g 6 bushings will be included, 4 normal bushings, and 2 eccentric bushings. This is needed in a 2g because there is no shifter cable adjustments. You can use these eccentric bushings to adjust your shifter cables on a 2g by slightly angling the shifter cable bracket, or use the normal ones if you have no adjustment issues.
Ive had a problem in my 96 with the shifter being out of adjustment and no way to fix it. The shifter didnt have enough spring action keeping it in the 3-4 possition. So when I shifted 3rd or 4th I would have to push the shifter over rather then just relaying on the spring action. Due to this I shifted 3rd to 2nd and reved the motor to nearly 12,000 rpm. Everything was Ok and I went 9.56 the pass after that but it scared the shit out of me, and I had to come up with a fix for it.
So this is what I came up with. Works perfect in my 96 it feels like it should and I will finnally be able to shift the 96 as fast as I used to shift my 95.
$35 a set
Thanks,
Devin Schultz PM me if you are interested
Well, obviously you didn't look hard enough. They're called "DSM Cable Bracket Spacers" and Shep sells them.
DSM FWD Driveline Products
You can see them installed here.
Either way, you're not a vendor. If you want to sell items, become a vendor and you'll be able to post in the vendor announcements section.
Status
