ITSME4G63
- 3,427
- 2
- Feb 6, 2004
chicago,
Illinois
JIM!!!! how bout some imput here, these people are getting sand in their vagina
Syndicate13 said:You do know that the Evo motor sits in an entirely different orientation than our cars right? It *could* be done but the cost far outweigh the benefits. At the heart the Evo motor is *basically* the same thing that sits in your car, it just spins the opposite way. It is not feasible since you would be actually fitting a DSM body around the Evo drivetrain rather then fitting the Evo drivetrain into a DSM.
BigBoosh3712 said:The new 4g63 is in fact a wonderful engine. But how much do you think a swap like you're referring to would cost? Any logical person with enough money to do an evo to dsm motor swap will utilize the "late 80s 4g63" block and buy parts such as pistons, rods, stroker kit, etc that were developed recently (hence, having better technology). So you can spend X amount of money putting that evo engine in your dsm or spend the same X amount of money utilizing the same 6bolt block that was developed in the late 80s and use different, high performance, internals that were developed recently and much up to date with technology. Who do you think will benefit more in the end?
GPTourer said:Actually, the Evo IX to be released next year will reportedly have MIVEC+turbo. It will be the last iteration of the 4G63T before the EVO X gets the world engine that was co-developed by Mitsu, DCX and Hyundai.
I never said that you said it was better for acceleration, but I'm sure you would bring it up, as you did. I don't get what you're saying and I don't think you understand what I'm saying. In racing, more often than not, fewer gears are actually beneficial, since shifting wastes time that could be spent accelerating. Do you have any idea how many drag cars and dragsters have only 2 or 3 gears? Or no transmission at all?Injected said:I never said that an extra gear was better for acceleration. The gear ratio argument is kind of pointless since the whole idea of the closer gears is to stay in the sweet spot of larger turbos and that is counter to what you are saying about taller gears.
For most DSMer's, all we want is a very fast, very reliable daily driver. The new 4G63 is simply a better engine since it is newer and uses far better technology.
Wow, such amazing technology. Those hollow camshafts probably allow for another whole 1-2 hp. And sodium filled valves, Jesus, truly space age technology!GPTourer said:The Evo's hollow camshafts, sodium filled valves are just a few things they talk about.
leakyfaucet said:Wow, such amazing technology. Those hollow camshafts probably allow for another whole 1-2 hp. And sodium filled valves, Jesus, truly space age technology!
With such extreme cutting edge technology, it's a wonder that auto makers like Ferrari and Porsche don't ditch their old school POS engines for these godlike Evo engines!
This sarcasm was in no way directed towards GPTourer, just at people who think the Evo 8 engine is somehow a magical high tech wonder.
ITSME4G63 said:JIM!!!! how bout some imput here, these people are getting sand in their vagina
leakyfaucet said:This sarcasm was in no way directed towards GPTourer, just at people who think the Evo 8 engine is somehow a magical high tech wonder.
Gee thanks, that makes everything okay.
DSMJim said:Has anybody ever really proven that putting a 1G head on a 2G motor is better or what? From the looks of it and what I have been discovering a 1g head (other then the cams) will be a power loss because of the way the intake ports are designed. They are on too much of an angle towards the valve, they are too large and will loose velocity. Does anybody have any dyno's or proof that the 1G head is better than the 2g head anywhere?
Sorry to go OT...
GPTourer said:Subaru had to punk out and come out with a 2.5L to beat it (and it still doesn't according to MT's head to head test of the '05 MR vs '05 STi)
Sorry that was an easy one to hit below the belt.
diambo4life said:Actually, the 2.5L was developed only for the U.S. market so it might be a little unfair comparing it to the EVO 4G63 that has undergone various revisions.
If there are, it may probably explain why there are only like four 2G's in the top 30 AWD times.
Injected said:I don't mean MIVEC N/A, I mean a variable cam tech. + Turbo. Ever seen a turbo Vtech car? Like that, but with a better engine.
DBR01 said:I don't think any of you even know what MIVEC does......it's not a power mod at any level......it's for better gas mileage.....it simply runs off of 2 cylinders instead of 4 under certain conditions
GPTourer said:That is so not true. MIVEC stands for Mitsubishi's Intelligent Valve timing Electronically Controlled. Its in use in the 4G69 that is in the Outlander, Lancer Ralliart, and Galant 4cyl. It works similar to everybody elses VVT, VTEC, etc and so on.
While it could be used to improve fuel mileage, it is not a displacement on demand system. I don't deny that it helps more mundane cars like the Galant get better mileage (30mpg on the highway) yet it is bigger, heavier and more powerful (160>140) then the car it replaced. It might also be used to help a car like then Evo maintain its midrange punch (and perhaps supplement its top end) but have a more emissions friendly and gass miserly tune at idle and low RPMs.
