driveshaft safety loop
kilo4
Supporting VIP
276
5
Apr 26, 2009
Fairfield, California
I searched around but only found a couple pictures of a driveshaft safety loop for 1G. I'm hoping everyone can upload a photo of their loop to help others. Frontline Fabrication makes a nice loop for about $145, but the guy was on vacation and I couldn't wait. Anyhow, I purchased a universal kit from summitracing for $28 shipped. After cutting and welding this is the loop I came up with. I wanted something bolt on and not permanent. Some people bolted the loop on the floor board, but that wouldn't work out for me.
It honestly looks really good, like it was made for a 1g.
I like this kit because it can be welded and assembled with the drivetrain installed. It wouldn't be hard to copy this set up. No body modifications required, I should have taken more pictures and made a FAQ.
Here's one that I put on my 1G about 4 years ago. It's a regular off-the-shelf universal loop. I didn't have to modify anything to fit it here. I never ended up using it or finishing the car before I ditched the project, but if I still had it, I'd be chopping it up and welding it to make it fit upright, be more compact, and to also ditch the hardware.
are driveshafts that lethal? I've never heard of one flying apart
It's not common to have one come apart on a DSM ( though it has happened plenty of times), but it is common it other forms of racing/motorsports. Around here, all of the dirt circle tracks are mandating the use of carbon fiber driveshafts. They've had too many instances where drivers are being impaled by steel shafts after a u-joint lets go. CF shafts will typically always splinter and shatter when a u-joint fails, so they're a bit safer.
But, most DSMers that are running a loop are doing so to meet racing requirements of a santioning body (NHRA, IHRA, etc). It's also handy to be able to roll the car around with no t-case and not have the yoke banging against the ground.
I plan on running slicks at the track and it's a requred safety item. Besides that, it's nice to have a piece of mind just in case it breaks on me.
Nice pics, I'll try to get a pic of mine up too.
It's nice to have a driveshaft loop on a DSM just in case the Tcase breaks.
Here's a couple pics of my driveshaft loop. I cut the loop shorter so it fits close to the driveshaft and clears the exhaust. It also fits high enough so there's plenty of ground clearance.
That's a nice loop Dave, I didn't think of this configuration. This would have been easier to install rather than welding it together.
I think the circle piece of metal with the FF stamped on it is definitely worth $145. I can't believe you only spent $28 on yours and it serves the same purpose.
TalonDave had one break apart
<iframe width="560" height="349" src="http://www.youtube.com/embed/l29S4f0keC4" frameborder="0" allowfullscreen></iframe>
