Driverside Window help!!
GeKo
68
Nov 15, 2007
Altamont, Illinois
well, i was fixing the rattle on my window and i noticed their was a bolt through the window itself near the door handle, so i lowered the window and started bolting it down, to my surprise... The bolt broke!!! AHHH!!!!
So, how do i get that bolt from out of the actual window and put in a new one? my window wont go all the way up/down now..... :/ anyone had this problem? or even know what im talking about? HELP!!! My window's electric!
This is the bolt i broke off, and now i have no idea how or where to order this part, let alone take my window out. I know there are how-to's but is it hard??
I don't have a 2G but I have gone into my door to try and fix my loose windows. Really its nothing too hard, somewhat time consuming but really not too bad. You can probably get that part from a junkyard/mistu dealer/Auto parts store (NAPA, Autozone, etc.) You might look into using a screw/bolt removal tool to save the glass.
It's not hard to get to the window or remove it but you have to remove a couple bolts to remove the window from the car. To get to the window, usually you have to
-Find the screws on the plastics of the door (usually 2-3 in different areas)
-Remove the door plastics by pulling carefully along the sides until door plastic pops off.
-Remove the plastic barrier if no one else has been in there before you (save this if possible. Keeps heat or cool air in and helps reduce air movement and to seal the car.
Thats about it. Have other questions, you know where to go.
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
