Drivers side axle carrier bearing with ac delete
See. My 90 block doesnt need that bracket there. I really just bolt in the intermediate shaft bracket to the back of the block. However when I told a friend he didnt need it he showed me he did.
I have a 90 (Vr4?) Motor. Can anyone add anything to this, as I am curious.
I do not believe anyone makes a spacer. When I removed my A/C, I just used a cut off wheel to cut off part of the A/C bracket to keep as my spacer. You need it, otherwise it wont be long until the bolts for the carrier snap off in the block.
FWD uses a long axle. No intermediate shaft. There is an OEM spacer that was used in other mitsu cars that needed a spacer for the intermediate shaft, and I'm pretty sure the part # 19Eclipse90 posted is that part.
I think 19Eclipse90 is correct, there is a factory part number for a spacer for that location. I know because I found it once and ordered one, it currently resides on my car, and I bought it from a Mitsubishi dealer so I know it to be.
