drewbird91
- 121
- 0
- Nov 30, 2004
Milwaukee,
Wisconsin
I searched first, but my question is has anyone drilled a few holes in the prothane mounts to allow it to flex and not cause as much vibrations? Just holes straight through in the same direction as the bolt. You think it would help alittle? I don't mind the vibrations that much, but my bolts that hold the turbo to the manifold come loose I think the vibrations are what is causing that, along with the heat. Just an idea. I don't want to swap the prothane motor mounts out, neither does the girlfriend, she likes the vibrations,
Let's discuss.
. Her car also has prothanes.
