door will not unlock
get could be a bad piece between the key lock and the door clasp. youll have to get in side the door to see whats wrong
Sorry to bring this back up but it seems I'm having the same trouble.
I cannot unlock my driver door with the key. It turns freely left and right, but doesn't unlock. Before, it had a bit of resistance. I can lock it fine from the switch on the inside and can easily unlock the passenger door with the key, but it sets off the alarm when the doors are locked. :notgood:
Also when locking the car with the switch, the thing that moves on the door with the red and indicates that the car is either locked or unlocked, takes a couple of pushes on the button to completely lock the driver side door. The passenger door easily locks on the first push.
Sorry I don't know what to call that thing LOL
You need to get a new lock it shouldnt turn freely
With the key in but the linkage disconnected it will.
IceCold needs to open the inner door panel and start checking the linkage rods and their clips. He should be able to see if the arm came off the lock cylinder. That might require replacing the lock.
