door open sensor
eclipsegsx1736
Supporting VIP
1,599
44
Nov 11, 2003
Los Angeles, California
I cant find the door open sensor switch. The driver side door doesnt trigger the interior lights, so I believe the switch is stuck. Can anyone snap a quick pic of where it is? It would be greatly appreciated. :thumb: I tried looking for it quickly and didnt see it.
:dsm:
It's on the back side of the door opening of the body. . Where the door and the body meet. It's a little black button with rubber on it. It must be common because mine sticks all the time.
Mine don't even turn the craps on... I wish someone could give the part number and a quick how to on how to replace the things...
MD598418
Lift rubber cover, remove phillips screw, extract switch, disconnect plug, reverse.
If it takes you 15 mins to change it, hang up your keys. :)
Steve
or just take them out and clean them super nice, and save urself $5 and go buy some candy :thumb:
same happened with mine. Those little switches are actually the same or work with many many switches for different cars. i found that most will work with my car
i cant even unscrew mine...it's only the driver side too..the passenger and tail gate work fine...nice rust formed around the screw so i cant turn it..any suggestions?
