doing a head swap...
arson
199
Oct 7, 2002
Kennewick, Washington
and it tells me to remove this pulley:
i got all the bolts out but one. how do i get the last bolt out?
a wider view:
its the pulley by the red paint.
thx guys!
I left the belt on to break loose the bolts then loosened the belt to spin the pulley to where it was easier to get a wrench on each bolt. Hope that helps.
Oh and yah, a dogleg wratcheting wrench would work nicely (if you got one).
That last bolt on the waterpump(?) pulley was a brain teaser to get off. I put another bolt back in and messed with both of them by tightening the loose one and breaking loose the tightened one and then trying to get both off. It was a pain but I got them both off. You have to hit it hard and quick otherwise it just rotates. I also put like screwdriver in one of the holes while smacking the bolt loose...memory is hazy but I did something like the above.
tried puttin a screwdriver in there, but it just flexed and didnt really stop it from turning. i'll try the 'put another bolt in' trick and see if i can get it loose. thanks for the tips guys :thumb:
