Doing a 16g upgrade. need a little info.
Shamrokk
82
Jan 24, 2011
Hattiesburg, Mississippi
On my 6bolt swapped 2g, my 14b is starting to give out. From what ive reaearched all i need to run a 16g is a evo9 fuel pump. Is this true? I dont want to do any tuning or bigger injectors yet.
16G is a direct bolt on replacement for the 14b, only difference is the Oil Return line. As far as boost difference you can do a stock pump rewire, and should be able to run it just fine. I wouldn't crank it past 15psi or so personally, but some would just crank it up till they hit fuel cut. Might even fuel cut at 15psi.
Direct bolt on if you have a 14b on it now. Keep boost at the wastegate level until you get supporting fuel mods and a logger & tuner.
