Froyd79
- 295
- 1
- Jul 6, 2003
Altoona,
Pennsylvania
obviously icing the intake on a drag setup is good but for daily driven 12 to 13 second cars do you let your car cool or just run it at normal operating temps. Trying to guage if im wasting time trying to keep it cool at the track. In my experience my car ran better at normal temps than if I let my fans on and let it cool for extended periods of time. Any info guys!
...sAD) First few times at the track Id be running both fans, hood open, popping the hood on the return road..It dont mean shit. Heat=detonation. These cars dont detonate unless much boost and shitty gas. Run it hot. A stable temp is better for consistency as well. If you had a dry sump, then cooling that would make sence but blowing cold air on the block doesnt do much else than screw with the maf/IATS VS oil temp. Run it the way its meant to be run, ice down the intake and upper IC pipe. Cooling down is for cars w Carburators. Not cars with ECUs and actual operating temps.
Yeah, the track was pretty slow that day.
