does not stay on when starting
Ced
38
Nov 3, 2005
Lauderhill, Florida
i just changed the sparck plugs and spak plugs wires. After i changed the spack plugs wire the car stated and then it died. so i try stating it again and agian i even tryed to press he gas will starting and it just died the car wont stay on it wasint giving me this proplem in this way before.
what do u think it is and what should i do. Some guy i just talk to said something about fuel pressure
oh and by the way i am running a automatic ecu in my manual it wasint giving me proplem its just temperary whould it have anything to do whit my proplem
A couple of things to check are:1) Make sure your plugs are gapped properly (0.028 inches) and 2) Verify that the plug wires are connected properly between your coil pack and the engine cylinders. Hope this helps!
First of all, you have HORRIBLE spelling, grammer, and punctuation. At least put some effort into your question if you are looking for an answer.
And to answer your question, I would say your gap is off. Re-check the gaps, and if they are ok, then check to make sure the plugs are in the correct firing order.
