not starting
joe81988
Aug 17, 2008
Lake Peekskill, New York
I just finished putting a motor in my 98 gs-t, the problem is it won't start. im getting spark and fuel. i checked the timing marks and its dead on. when i try to start it it sounds like its out of time (backfires through the intake). i checked both the cam and crank sensors with a volt meter... they seem to be working. i also checked compression, each cylinder was around 140 psi.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
