not starting
talon_1992
Dec 21, 2006
warwick, Rhode Island
my car was driving fine when i parked it and i want back out to leave and it would not start checked every thing i could it was all fine till i checked the compression cyclinders 1 = 0psi
2 = 130psi 3= 130psi 4 = 0 psi does any one know what is going on with it :beatentodeath:
no its not that caz i just had the timing done and new valves put in my friend thinks i maybe the pistion rings
Put some oil in the cylinders and see if that changes the readings any. That will tell you if the rings are a major factor. But then again having zero on 2 cylinders after it ran fine im thinking valves.
Just because youve had a new T-belt installed dosent mean it couldnt of jumped time the tensoiner could be bad or not enough tension on the belt, I doubt its rings with 2 cylinders having 0psi.
well all the stuff for the timing is new the head is new also before the new head was put on it was off for like a mouth and a half and the two pistons in the middle where at top dead center and 1 and 4 where all the way down but it ran fine till now
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
