Does DSMLink support two fuel rails?
gSx_r1der
329
3
Oct 14, 2004
Jamaica, New York
Does DSMLINK have the ability to support two fuel rails?? Using one rail at idle and cruise and then both at and full throttle ???
DSMlink is the factory ECU which has been modified to allow the user to change certian settings and most imnportanlty log! DSMlink does not directly support 8 injectors (2 rails), but it can allow the user to change global and dead times to allow much larger than stock injectors to idle while supplying the additional fuel at WOT. I have seen DSMs with 1200cc injectors idle just fine. And those injectors had plenty of room left for WOT pulls. Why dink with 2 rails, 8 injectors, 2 supply and return lines when the stock deliverly setup will suffice (for most people)?
IE keep it simple.
Will stock fuel rails handle 4 850cc injectors ????
EDIT: And will stock fuel lines handle those injectors??Or do you "HAVE" to rewire the fuel system??
