does anything with the 420 have an MFI/MPI?
For youor n/t 2g, The fuel pump and MFI relays are located next to each other inside the car on the passenger side behind the center console. Take off the plastic interior panel which your left leg would rub against if you sat in the passenger seat. The two relays are mount on a vertical metal bar behind the removed interior panel.
Now, I'm getting a few mixed answers as to where they are located, Still:
" when you open the hood and look on the firewall behind your battery..you should see two relays on a metal bracket.
the parts numbers for what you need are o4687567 and o4671047. look them up at a website that searches oem parts by number. "
