does 1994 wheel bearing fit on 99?
thricestrat
66
May 17, 2005
North Tonawanda, New York
i can only seem to find the front wheel bearings for up to a 94 rs eclipse...i have a 99 rs...are the bearings the same? and also are the hubs the same? if they are should i bother doing the bearing and have it pressed or should i just buy a new hub?
p.s. plz help car sounds like crap....
call the dealer and ask if they have them for either car, ask for the part numbers. if the numbers are not the same i would not interchange them.
doing the hub or just the bearing is your call. little more work to save a little money, you have to decide what its worth to you.
alright thanks ill prally do the bearing
another quick question was i ended up finding the gsx-t hub for a 99....would that hub not match cuz its built for awd or are they the same?
