cyclonekid77
- 383
- 2
- May 18, 2007
Bellevue,
Ohio
Im curious as to how accurate/trustworthy the stock knock sensor is. I have tried everything to get rid of my knock and nothing seems to help. If you look at my profile you can see the engine is nowhere near stock. I was reading in a post by cbrfrenzie that the sensor can pick up the sounds of the valves shutting if you have aftermarket springs(wich i do) and I wonder if that might be my problem. What gets me is the knock allways starts around the same rpm(5krpm), no matter if im running 8psi, or 15psi. Wouldnt more boost make the knock start sooner? I have tried changing plugs, nylon washer between the sensor and the block, just barley snugging the sensor in just enough that it wont fall out, changing timing, ect. Any suggestions would be greatly appreciated
How do you check air intake temps? Sorry, I need to learn ALOT about tuning. Thats why I get on here and ask questions
. So the 1g timing map may just be too aggressive for my engine and thats why I cant get rid of this knock? I want to get this figured out because I would really hate to blow a hole in a piston after spending all that money on building this thing.
