90GSEclipse18
- 38
- 0
- Feb 24, 2004
Pennsylvania, USA,
Pennsylvania
I have a 1990 GS eclipse, Do you need to remove the engine to intstall a new timing belt?
jbranne said:Make sure you put the crank bolt in using an impact, or at least use some threadlocker on it.
I changed the belt on my 1.8 and after many months, the bolt loossened up can caused all sorts of bizarre problems.....like the keyway in the crank sprocket getting fubar'd.
slow4G63 said:and just to let you know.... that there's a little cylinder thingy and that is the automatic belt tensioner. You have to unbolt that, compress the pin sticking out with a vice, stick a small nail in the side hole so that it will keep it compressed,
