do YOU know anything about an N/T trans???
speed127
85
Nov 1, 2005
Philly, Pennsylvania
Hey everyone.... I just bought this car about 3 months ago and have only put 156 miles on it because of all the problems I've had with it. And now I think I have my biggest one yet. First off, my emergency breaks are shot, and at $40 a side just for the parts I've not done it yet, so when parking I put it into gear to keep it from rolling. Well 2 days ago, I go out to drive it and can't get it out of gear for like 5 min. Once I finally do get it out of gear, I can't get it to go back into any of the gears for a while. I do after a while and just decide to leave it for another day... I have only learned to drive a stick using this car so I'm still a little new to it and how everything works. (it is SOO much fun though):sneaky: So then yesterday I read the chiltons, and checked the clutch fluid and it's bone dry. So I fill that up and since it's wet around where the fork goes through the boot in the trans, I also check the level of the trans fluid. It seemed a little low... maybe a quarter in. lower than it should be but since I didn't have any fluid I just left it cause I thought it would be ok. Since I was in the driveway my car was in neutral and I started it and there was this LOUD grinding, whining noise. I quickly turned off the car and then had my cousin start it and quick turn it off, for me, while I listened to which side it came from cause it almost sounded like belts were slipping but alot louder. Well it was defenatly NOT the belts so I left it for today. I got some more trans fluid from the dealer ($11.00 a quart) cause I thought that might be the reason and filled it up, it only took a little bit and then I realized that I hadn't bled the clutch so I did that too. I again tryed to start it up, in neutral with the clutch in and it was fine... until I started to let the clutch out... then there was the noise again... My father-in-law said it may be the through out bearing but thinks its odd how it happened so sudden. Like one day I could drive it and the next I have all these problems. Also this leak around the boot where the fork goes though, he says should be a dry place in the trans. So what should I do? I'm not sure if I can do the work on it myself although I not too bad at working on a car, I's just I don't have a lift, AND i've never messed with a trans before. Also could it be more than just the bearing? I'm almost leaning towards geting a new-used transmission from ebay or craigslist for maybe $500 but am not sure which one wil fit my car since I have the N/T version. I also believe it's the chrysler one since I saw the chrysler symbol on it. ANY help will be AWSOME and sorry for the long read, I just wanted to give you all the details and what I did. :confused:
ANYONE?? can I put a 4g3 or g6 trans in? or I've even heard of someone using a nission 240 trans. please I do need to get this fixed or even just know what my next step should be.:confused:
You would be better off to just rebuild the tranny that is in the car. A 4g63 trans won't work because the engine is on the other side. If you do get a used tranny it has to be what is in it now. The loud noise could be a wore out clutch disc, the rivets could be touching the pressure plate or flywheel.The boot around the clutch fork probably had something leaked on it or spilled on it, Its sole purpose is to keep water and dirt out of the bellhousing.
yeah, if i were you i would replace the clutch, i had a similar problem, and i replaced the clutch, and the problem was gone, so buy a clutch, its much cheaper then a tranny
do not try and rebuild the trans the output shaft in there with the 1/2 syncro assembly is an interference fit on the shaft and you can not change the syncros. All you can do is buy a new shaft with everything already on it and that is priced at 1500 dollars for that shaft alone. Just try and find one out of a junk yard that works or a reman unit but dont rebuild it.
