Do they make this fitting?
alice
309
Sep 7, 2006
Canandaigua, New York
I have looked at hundreds of pictures looking for this fitting. I am looking for a -6an straight fitting that has a male flare instead of a female flare. Do they even make one like this?
I have pretty much looked at every fitting they have listed and can't find what I am looking for. I might give them a call tomorrow to see if they can help me out. Thanks for the link!! Here is a pic that may help describe what I am looking for. First, I need a fitting to attach to the stock 2g AWD Fuel sending unit fuel feed line. The stock fitting is still on there and the line from the sending unit to the fitting is good.
I need a straight -AN fitting that has an end like in the black circle (male flare) that would go into the the end in the yellow circle(female flare).
Hmm, so you need something to connect to the stock fuel line fitting? I bought one of those awhile ago from ANPlumbing.com, IIRC it was the 14mm female -6AN male part # 9894DBH
I cant quite remember if that is the one I bought :coy: so if someone could double check me here, but that should connect straight to the fuel line fitting. I could not locate a 14mm female -6AN female fitting
