What Fitting is this?
Flash
3,359
14
Nov 30, 2003
Highlands Ranch, Colorado
I want to change my fuel feed to -6AN and I want to start the SS line under the car at this fitting.
I was wondering what fitting I would need to order from Summit Racing to attach to the hose that goes from the tank to under the car and meets the hard-line (look at picture).
Grant, accoring to the stevetek labs fuel system page, the standard -6 female threading will thread onto the fuel pumps outlet fitting that you show. The just use telfon tape to seal it up.
Take a look. Its toward the bottom.
http://www.stevetek.com/R-FuelSys.html#S13
However, If I were you, I'd eliminate that stock line that goes into the tank also. Drill it out and install a -6 90* bulkhead fitting and related fittings. IMO its a much cleaner, and much more well done setup.
I just got rid of my -6 stuff, and I just upgraded it all to -8 and it looks very nice.
Excellent that is what I needed. I guess I will start using AN fittings on top of the fuel pump assembly instead of under the car.
About making it 100% true -6AN, once I gain the experience from messing with this fuel line, I will then attempt something of that nature.
Hey Dan, I just finished installing my -6AN line and fittings last night. I used the guide you referenced to and everything worked. I'm skeptical about how long the -6 straight fitting will stay sealed at the pump assembly though. But so far there are no leaks and everything is tight.
I will track down my invoice and post my parts list later, I did a few things differently then the guide you linked to did.
