do these fit?
noss88
98
Feb 20, 2009
Bayarea, California
i've searched, but didn't find an answer to my question...i'm looking at some rota subzero 17x7.5 +45 offset, do they fit on my 2g with stock suspension?
They should.. 7.5 is small considering and the +45 should bring them out quite a bit.. Tire choice is everything..
The higher the number, the closer to the inside of the car. On my '95 AWD, the factory size was 16x6 +46. Adding another 1.5 inches will give you 18mm less clearance on the inside, and extend 20mm from my OEM wheel size.
Agreed, tire choice is equally as important.
I ran an 18x8 +45 with 225/40 tires with no rubbing problems on a lowered suspension. No rolled fenders.
I currently run 18x8.5 +44 with 235/40 tires with slight rubbing in the rear. No rolled fenders.
You should be fine on most aftermarket as well as OEM suspension set-ups.
well im picking them up this weekend for $300 in almost mint condition, what tire size do you guys recommend? i just emailed the seller to see if he can let me know what tire size are mounted currently since they still have 50% thread on them i might as well ride them till i really need to change them.
Edit: he told me they're 45 series, i'll update this thread tomorrow if i pick them up tomorrow, thanks guys
hey guys, i picked up the rims today, the tire size is 215/45/17, will these still fit on my car?
cool, thanks, btw really like ## ride with the gold rpf1s...i'll get them mounted when i got the time
