DKS lifter shims.
4g63t
1,568
13
Aug 14, 2005
North Iowa, Iowa
I just baught a set of dks 264 272s from a member on here and I was wondering how i check to see if i need lifter shims. I tried contacting ffwd but because I did not buy from them they will not help me. I have herd that if you have had a few valve jobs done that you do not need them and i just had one done. this is what i was told " if you do need them then you could go to the hardware store and get those shims (essentially washers) in a 18-8 #10 size stainless. They are .030 thick (most important to be it that thick)"I just need to know what to mesure to see if I need them. Thanks for any help in advance.
He refused to help you because you bought them used? That's kind of stupid since he is technically selling used cams to begin with. I think somebody posted a copy of the instructions that come with the cams. I'll see if I can find it.
