DIY water injection help
Status
Not open for further replies.
dsmoverboosted
217
Feb 26, 2006
Winnipeg,
Well I am thinking of making my own water injection system and I need some help and opinions with the build. First I am thinking of just tapping into my winshield washer resivoir under the hood, running a line to a 12v water pump and run a line to my uicp.
My questions are
A. what kind of pump would I need? how much psi rating or gpm should I be looking for?
B. Can I mount the pump under the hood or is it too hot under there?
C.What would be a good way to control the spray? Is there a pump I can buy that will turn on with a certain voltage like say whatever volt I get from the tps at %90 throttle or something. Can I get a solinoid that will open after a certain psi is reached in the system (I like this idea better). If so where at.
D. what kind of nozzle should I get? Can I use a nitrous nozzle (I might be able to get one cheap)?
If there is anything else I am missing or if there is any suggestions from some injection specialists I am all ears.
Thanks Axe
Status
