DIY camber kit
blackhawk2k7
98
Oct 12, 2008
Stanwood, Washington
From what I see, there is plenty on the 2g "Home depot" camber kit, but I just had megan racing springs put in my talon and les schwab did best they could to align it, but my rear camber is a slight bit off, and instead of wearing tires, I was wondering if there is a DIY 1ga camber kit, or do I have to go with the buy it kits online?
well camber wont per say wear your tires off its toe that will do that.
But you can make your own control arms OR buy the DME Camber kit off of Extremepsi.com
its like 50 bucks or so and doesn't take long to do as long as you can get the control arms out.
I have the same springs on GR-2's with the DME kit.
Now its going to cost your roughly 70 bucks to make your own. So you weight your options but the DME kit or Ingalls kit (200 for the car) is your basic choices.
Camber, toe in/out, whatever....
I saw the 55$ version a moment ago, i think that that would be my safe bet, thanks
Two totally different things, point being, you shouldn't have to worry about tire wear if the toe is good. Look at the camber on some 5-series BMW's.
