Dislodged weight causeing vibrations
Hesh724
373
Feb 7, 2009
Hopewell, Pennsylvania
the black dot "or small hole" where it looks like there was one of the weights same as the small rectangle marked by the X on the other side of the P-plate. it looks like there should be one in both spots. could this cause bad vibes. with the clutch out?
In gear? Moving? Stopped? All the time?
More details would help. Develop a little better sentence structure too, so we all can read more easily and distinguish exactly what your talking about.
My bad... Only with the clutch let out would it shake bad. I took everything apart and found that my disk is slitghly scorched, I have a very small crack on the inner lip of my flywheel and this. I'm fairly sure that the red square should have one of the weights hilighted by the green box.
Thanks,
That the pressure plate is still in balance due to the fact that it is bolted to the flywheel and spins with the engine rpms at all times. And there is no actual evidence that there was a weight in this extra hole there is no square of not painted metal unless they painted the pressire plate without the weights on and then with the weights on . so... just kinda thinking out loud. Just let me know if my logic is off?:banghead:
