disabled clutch start not working
bskills
53
May 11, 2008
Jersey City, New Jersey
Hi guys,
I decided to disable my clutch switch so that I could start my car without pressing in the clutch, but after disconnecting the plug, the car wouldn't start. Any idea on what might be the cause.
Thanks
not trying to be an ass, but if you do plan on taking your car to the track. atleast at the track here in NH, you need a working CSS to pass tech. but im sure you knew that already, just figured id throw it in here.
but heres a simple thread on how to do so, basically you unplug the white male connector thats located up under the driverside dash, above and to the left of your clutch pedal(atleast on a 1g)...
http://www.dsmtuners.com/forums/articles-drivetrain/192617-how-disable-clutch-start-switch.html
The CSS just activates the starter relay which DISABLES the starter circuit (relay is normally closed and CSS opens it) when the pedal is not pressed. So you can just remove the starter relay and permanently jumper the starter relay black-red wire to the black-yellow effectively eliminating the starter relay.
Thanks. I will give that a try this afternoon after work and let you know.
